Hi All,
I'm having real problems with the rad in my lounge.....I'm pretty hands on for a girl, quite used to draining down rads and flushing them through, but can't seem to shift this one!
The rad is totally cold...large double rad served by microbore 8mm copper pipes (yuk!), valve each end (non-thermostatic type). Have had the feed valve off the rad today, tried to flush through...lots of black sludgy stuff came through, then it totally blocked up. Took valve off..no probs there, clean as a whistle. Upped pressure on system to max via boiler fill valve, nothing came through the (now valveless!) pipe at all. Turned pump on and it started flowing a bit, lots of rubbish came out, but still not flowing properly, very weak flow. Put it all back together, rad incredibly slow to fill. Think there must be a blockage between the manifold (impossible to get to without clearing an entire room of furniture, taking up carpet, as is in the middle of main bedroom - argh...who planned that??!) and the valve, somewhere in the pipe.
Would adding some Fernex cleaner or similar maybe sort the problem out?? Or if it's not flowing well, is it gonna do diddly squat? Thinking only other option is to get somebody to do a power flush, but (a) massively expensive and I'm on benefits due to ill health and (b) I read theyre not great on microbore systems....?
Any advice anybody...pretty please?
