Our electricians cut holes in coving to run a feed into the kitchen. Can anyone tell me the best way of repairing the holes.... It is proper plaster coving.
Ordinary filler is fine for the job. Put a bit of cardboard in the hole first, build it up in a couple of stages, then sand it down with fine sandpaper.
