Hi- laying concrete slab over plastic sheet membrane. Have a couple of conduits with pipes in. Can anyone please confirm how to seal around pipes passing through vertical DPM sheet against wall?
You can? Thanks.
There is a couple of ways, depending on the size of conduit.
You can just use DPM jointing tape or you could use some of your DPM and form a gasket around the conduit, so overlapping, then tape it up on overlaps and bottom of conduit shaft.
