how do i secure solid glass panel to shower base
djd
1 Oct 2006
Pembrokeshire
i have bought a glass panel so i can have a walk in shower however it slots into the wall channel and is fixed at the top by steel bracket ,what is the best way to secure it at base level as it can be easily pushed off shwer base.
Tape it on the inside of the glass at tray point to hold it centred on the raised lip of the tray. Then good quality, anti mold, clear silicone bead on the outside. Let that set, remove tape then back fill the other side just in the glass to tray gap, no more, if too much it can eventually trap water and discolour.
Remember it's not designed to be leaned on anyway, if that's what you wanted then it needs to be a fully framed screen.
My shower glass came with a 'U' channel to slide the glass into. This channel was siliconed down to the shower base.
I did buy from here so that I could fit a 'U' channel down the exposed, free edge, because although it looked minimalistic it was difficult to relate to the edge and to therefore avoid bumping into it.
http://www.shower-glass.co.uk/u-channel/
