How do I tell....
10 Jan 2006
....if my system is pumped or gravity feed.
Sounds like a dumb question I know.
Nope. It's a potterton wall mounted boiler.
Reason I ask is I was told by a plumbner in for another reason that i have an olf grtavioty feed system that I should really replace with a pumped system (not the bolier says that is OK!) and that the tank will need replacing as well.
Now my FIL is saying we should do it and I smell cow's droppings.
If the pipe to the coil of the cylinder is big enough to drop a pound coin in, it is probably gravity. If you have a 3-port valve, it is fully pumped
