How do I wire a cylinder thermostat to a central heating pump?
I have an HTS3 cylinder thermostat that I want to use to turn on an off a Wilo Gold RS50 pump.
This is part of a very simple system I have created in a garage. I am heating the water in the tank separately from any boiler or the like, and that's not the issue.
I am not trying to use the stat to control the heat, or the method I use to get heat, I am trying to control a pump.
When the water in the tank reaches 50 degrees, I want the pump to circulate the water out of the tank and into a single radiator and back again.
Simple.
The HTS3 stat has three connectors in it. One is 'common, one is '1' - call for heat, and the other is '2' - satisfied.
The pump has three connectors too - live, negative and earth.
THE QUESTION:!!!
How do I wire the stat to the pump? I will have cable coming from 240v mains supply - -three wires, live, negative and earth.
Many thanks.
ps, sorry if this should have gone in the electricians forum, I wasn't sure where it should go.
Simple.
THE QUESTION:!!!
Many thanks.
