How do you Plasterboard round a girder?
26 Aug 2007
Cumbria
Hi, How do you plasterboard round a girder?
I've seen people hammer in pieces of wood to the side's in order to board the sides, but what about the bottom?
Cheers
nail them to the wood at the sides
you want to end up with the wooden frame of a box round the steel.
when fixing the side plasterboard, allow it to sit down below the steel flange by 18mm. then dab some board within this slot with full fill dry wall adhesive.
ah ha, Thats how its done
Better still, score the board on one side so that it wraps around the beam.
ie You have a strip with two folds in it so that it can fold into a u shape the same dimensions as the beam. You tack one side aas normal, you can put a bit of adhesive or gripfill on the beam , wrap the boiard around it and tack the other side as normal.
(You have noggings in each side of teh beam)
