How do you repair an F12 fault on a Hotpoint Aquarius WD440?
25 Mar 2010
Lanarkshire
Hi, I hope someone can help. I have some flashing lights on my Hotpoint Aquarius WD440 washer dryer when I turn it on. After some searching online I managed to find a list of error codes on this site. From the list I found it would appear I have an 'F12 - communication error' but I can't seem to find any suggestions on the cause or the cure of the problem. Is it likely to be a loose wire/connection/plug or is it more likely to be a pcb? Any help would be most welcome. Thanks in advance.
unplug the connector block on pcb for 5 mins if that dont work new pcb needed.
Thanks for the tip. Take the top off to gain access and the PCB pops out. Easy to remove the connector. Quick clean and all well.
