if so, you turn the power off, disconnect the live and neutral wires and take a restace reading across the live and neutral on the pump using a suitable electric meter.
more than likely no it wont. cant remember off hand what a pump gives, maybe around 160ohms, thats a guess, sure someone will corect me. (plus different pumps will have different readings, it will be a general reading you should expect ie not a few ohms indicating shorts circuit and not Kohms or Mohms indicating a fault)
