Oh no.. testing motorised valve and....
18 Aug 2008
London
Hi
I have just tested my motorised valve (HONEYWELL 3 port mid poisiton type) - the HW and HTG are both off but I pushed the lever arm across to MAN and i felt resistance... on return there was no resistance and then when i moved it across again to MAN there was still no more resistance! Have i buggered the valve up? All I did was push it across out of curiosity to test it!
Should I have turned on HW before testing??!!
Is this supposed to happen??!!
thats not really "testing" it, try turning HW on and it should return to its normal (port A closed) position. then try the heating and see if that works
Hi
I put HOT WATER only on and the valve had resistance when moving the lever to the MAN (OPEN) poisiton.
but when i returned it by hand again to AUTO there was no resistance felt and then when again pushed across to MAN (OPEN) still no further resistance ..
why is this?
the valve is being held in it last position, normal.
isolate the power from the fused spur then turn back on it will reset.
thanks seco services for your help.
so basically it is is mid position now until i turn it off and back on again to reset it.
have just turned hot water only on again (reset it as you said) and it is like before, resistance at first when pushed across, so it is working correctly.
i guess if when hot water only is on and there is no resistance felt at first, then the valve is open to both circuits and is faulty, probably i am thinking due to a faulty spring ?
Rarely the spring.
More likely just seized, or faulty wiring, which is the most common fault after a dud motor.
try turning on HW - does it work
turn off HW and turn CH on - do rads heat up
turn on HW - do both work.
Could be due to a faulty internal switch or wrongly wired. And sticking, can be intermittent.
if when hot water only is on and the level had no resistance felt when it was moved to the MAN (ON) poisiton, then surely the valve wouldn't be seized (as the lever would not move) This would mean the valve was loose and open to both circuits wouldn't it, but it wouldn't be from being seized up would it not?!
What is the plumbing and/or central heating problem that you want help in solving?
:oops:
I was just testing my valve and it all started from there really ... curioisty i suppose.
thank you all for your replies and help.
it has been appreicated very much.
btw - what do you mean sticking is intermittent (i know what intermittent) but what exactly would be sticking? the spindle?
Leaving aside the fact that you weren't testing it, you haven't actually said why you weren't doing what the rest of do with working zone valves, i.e. leaving them well alone.
i was just testing it and fiddling about and curious really!
well there was nothing else to do today! 2 crappy footie matches on that weren't exactly mouth watering!! but that was about it! :LOL:
