I think there's a rule about how far you have to come off an unvented pressurised cylinder with copper pipe - thunk it's 3m? Is this for the hot water take off or the flow & return though?
well it won't be going in the living rm, I just want to do what's correct. Using plastic is much more preferable as need to bend and negotiate slightly where the pipe comes thru an existing hole in the wall.... plus I don't have any copper avail at mo. I'm replumbing as much as the house as poss, doing away with copper where I can.
