Hi folks
We recently bought a house. Today my wife bought some plastic backfits for the switch panels that can be fitted without removing the panel. As I was fitting them, I tested the screws that hold the panel to the box in the wall. The tester glows. It made me check all the switch panels in the house and on some of them, the tester glows but rest are ok. Infact we did a paint job over these walls recently. Nothing untoward happened.
I happen to have a cheap digital multimeter. I never used it till today. Read the manual and checked the culprit screws duly. I am not an electician by training or by imagination. I can fit a switch or a light fitting if it comes with two holes for two wires
Now I am worried whether it is dangerous. When I tested with the multimeter, it only gives about 1 volt. I am not even fully sure if my testing is right.
What do you guys think is the best way forward for me?
Is it normal for there to be a feeble voltage at the screws of the switch panel?
The house is built in 1930s, in UK. Electrical work seem to have been updated as the control panel has the trip switches and RCD etc.
Ta
sk
Ta
sk
