How to connect to 3/8 hose?
r_c
19 Jun 2016
This is my first attempt at changing a tap :) But I am stuck as to how to connect the hose to my existing pipework. Can you please tell me what part I need
I am trying to fit a new Grohe kitchen tap. The hose appears to be 3/8". The isolation valve is on a 15mm pipe. I hope the photos help.
How do I connect the 3/8 hose to the existing 15mm isolation valve?
It looks like I will still need another metal hose as the Grohe hose is not far enough?
And is this only an issue because I bought the tap from a German eBay seller?
Thank you.
Thank you @muggles . Screwfix isn't far so I'll give that a go. But it seems to me as if only one end of that connector is threaded and the hose and isolating valve in my situation are both threaded.
You'll need a nut and olive on top of the existing isolating valves.
  • Thanks
Reactions: r_c
You are missing the nuts and olives from the top of your ISO valves. I presume the previous installer just nipped the flexi's straight onto the top of the ISO.
You need 2x15mm nuts and 2 olives.
  • Thanks
Reactions: r_c
The finished product. New tap seems to be working well. Thank you all for your help with this! :-)
I now want to go and learn how olives work!
At the end of installing this tap I had a small white sachet from Grohe with German writing on it. Google Translate tells me the German says "synthetic grease".
Have a missed a step?
Not really, you use the grease to lubricate the o-rings that are on the tap end of the flexi tails, just ensures they slot into the hole properly. As long as it's not leaking then I wouldn't worry.
  • Thanks
Reactions: r_c
I have a random IV in my plumbing box with an unusual fitting on one side, maybe it is for these new fangled microbore tap cons
