I need to change the position of a radiator in our living room so will need to drain our CH system.
We have a cylinder gravity fed system but our CH is a sealed system you fill it directly via the mains using a stopcock and you check the pressure using the pressure gauge above the boiler. Hence I don’t think there is a separate feed tank in the loft.
If I drain the system, how do I refill it with anti-corrosion fluid?
