How to finish roof off with only a 150mm gap.
11 Apr 2006
Lancashire
I'm currently having a single story rear extension built. I live in a semi and my extension runs parallel to my neighbours flat roof extension for 3m of the 6m length. The height of my wall plate falls below the height of their flat roof. I'm just wondering what is the best way of finishing the roof off in such a confined space. What is the procedure for getting the facia, soffitts and guttering on when the gap is only 150mm space. Thanks in advance.
Build your wall further over.
Or with his written permission do box gutter like this:
Trying to do a traditional eaves in such a small gap is a bit of a non starter, you won't physically be able to fix any of the components together.
I'd go with the box gutter idea. I recently had a job where someone had done a similar thing between two roofs on some bungalows but had used bog standard 4" plastic guttering with one run just above the other. They did have a slightly wider gap of about 12" but it was a pretty poor job and water was getting into the cavity and running down the wall. The answer was a box gutter but it was a pain retro fitting it having to construct it outside and then lift it all into place.
I like the box guttering idea. Would you run the box gutter the full length of the 6m, fixing the last 3m to my side where I can have access or run the box guttering into a standard gutter for the last 3 m? Thanks
North west seamless guttering can do you a full length of ogee guttering, you could fix as normal on the end you can get to and put some straps on the end you can't then hang it down until you have the correct fall and nail the straps to your rafters.
