Hi guys,
I would like to install 6x2 joists in the loft of my 1950's semi to make it more load bearing, however I am having difficulty trying to figure out how to secure them each side of the house.
On top of the external brick walls of my house there are big beams of wood (I think this may be called the wall plate?), it looks like the size of a purlin, I assume its how the whole roof structure sits on the brickwork.
The problem I have is the plasterboard ceilings are level with the top of this wall plate so I cant install joist hangers on the side, and the rafters of the roof rest on top so I only have a few inches gap if I was to rest a joist on top. I could cut the joist to the same angle as the rafters to make them fit, but then the joist would only be supported by a fraction of its original thickness making it less load bearing.
Please take a look at the picture attached, imagine it is a cross section cut of my house. Basically I'm trying to fix the 3x2 joist to the external wall somehow to make it load bearing.
Does anybody have any solutions?
