    Dismiss Notice
How to get the correct render finish
Discussion in 'Plastering and Rendering' started by Azurite320, 28 Aug 2009.
  1. Azurite320
    Azurite320
    20 Mar 2009
    3
    Thanks Received:
    Suffolk
    Country:
    I need to hack off and replace about 1/2 sq metre of blown rendering to the front wall of my house, under a window.
    Is there a premixed render generally available or do I need to mix the render? If so, what is the recommended mix and how do I go about getting the same rough texture?
  2. Sponsored Links
  3. trowelmonkey1
    trowelmonkey1
    22 Apr 2009
    857
    Thanks Received:
    82
    Oxfordshire
    Country:
    can't say for the finish without seeing it so maybe upload a pic?
    regarding the render itself, mix it yourself, for the scratch coat people seem to go for a 4:1:1 with plasticiser/waterproofer (4 plastering sand:1 cement:1 lime)
    then float coat with a mix of 5:1:1 and plasticiser, rub it up with a float to consolidate the surface but not too soon OR to late.
    there has been a post recently about when to rub up.
    • Thanks Thanks x 1
  4. Azurite320
    Azurite320
    20 Mar 2009
    3
    Thanks Received:
    Suffolk
    Country:
    Many thanks for the answer.
    I'll try the mixes suggested and see how rogh the surface is.
    I guess the hardest thing to do is to get it to match the existing render.
  5. trowelmonkey1
    trowelmonkey1
    22 Apr 2009
    857
    Thanks Received:
    82
    Oxfordshire
    Country:
    the surface won't be anything to do with the mixes, the surface will be created by how you finish the render, i.e.just with a poly float or a sponge too or by throwing pebbles into it and so on.
    getting it to look like the existing render will be nigh on impossible IMO, why don't you consider taking of a complete square the width of the window and from the window sill to the bottom of the render? would leave you straight lines at worst and wouldn't look as bad as random patches.
  6. Alastairreid
    Alastairreid
    21 Nov 2008
    6,456
    Thanks Received:
    1,025
    uk
    Country:
    agree with that! you wont get a seamless patch either.
    at a guess tyrolean finish.
  7. SCUDmcCOY
    SCUDmcCOY
    28 Aug 2009
    21
    Thanks Received:
    Country:
    1 part lime mixed with 1 part sandy loam.then soak it for 24 hours in horse urine after which it can be used for plastering.works every time.you should be able 2 get this at your local hardware. :)
  8. richee
    richee
    8 Sep 2009
    4
    Thanks Received:
    Country:
    i think cutting a square will make it stand out more then just patching it.
    also with such a small area, there is no point in using lime, and 5:1 for scratch and 6:1 for top coat. 4: 1 is too strong for external render
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
