how to hide tv cables in wall?
5 Aug 2008
Berkshire
Hi
We are getting a chimney breast closed up and plastered in a couple of weeks and want to mount a tv on it when finished. It would be good to have all the leads hidden. We dont have the new tv yet so were going to use the current one for now, but if we get all the leads buried what happens when we want to change tv's? Also the current tv has 3 leads plus a scart coming from it - is it tricky to bury a scart?
Its not tricky to bury any cables as long as you adhere to electrical regulations
I didnt when I dont mine but I was none the wiser so eventually a re-do will put mine right
Work out the distance from your TV to you Sky/Virgin/Freeview box mine was 5 Metres, also consider putting in extra HDMI (Buy online from Aria literally buttons you will be surprised) if you have 2 HDMI the put 2 x HDMI into your wall, one could do your set top box other could do blue-ray or x-box etc...
also consider putting a d-sub cable if you ever want a PC in your living room to act as a media server basically your TV will be the PC monitor so downloading films play them full screen works sweet, if you do go down that route you will need to add some speakers to the mix, 5.1 PC speakers will set you back 50-100 quid if you go for the highly recommended
regarding changing your TV and will the leads suffice, tbh its a case of suck and see, the ports may be in diffirent locations on a different TV so may not reach once burried, even if you leave a lot of slack that could be too much and hang down below your TV
its not a big job to chisel the wall out, insulation tape around all cables so they are all together, then secure to the brick then fill over, will be years when you change TV so few hours work chasing the wires out and re-alligning them wont be too difficult
Heres mine showing TV PC and 5.1 speakers
Hope that helps
When I decided to mount my TV on the chimney breast I decided to install a permanent 240V socket as this would always be required, but to run the signal cables through conduit terminating at brushed faceplates to that new cables could be run when required. I currently have 2 HDMI cables, but have previously run network/USB/SCART/VGA cables (removing and reattaching the plugs from the SCART and VGA cables to get them through the conduit).
And don't forget to get the hight right, get it wrong and it will be a pain in the neck, literally.!!
Ideal hight should have centre of screen at you eye level.
Mine isn't at eye level, and I love mine were it is
Was a bit wierd at first going from a black glass stand to on the wall but now it seems perfect!!
