how to install a washing machine in a celler
21 Mar 2007
Yorkshire
hello can anyone help i want to put my washer in my celler there is water and power but the outside ground level is about 1.5m above the cellar floor so how can i get rid of my waste water to this height :?
sani flow do an adaption for this type of instaltion
http://www.saniflo.co.uk/sanicondens.aspx
there are others as well check the whole website
SANICONDENS is a small (283 x 180 x 128 mm) but powerful pumping unit that will take the discharge from a condensing boiler or other water producing appliance and pump it away to a drain. The unit, which can be floor or wall mounted, will pump up to 4.5 metres vertically. It can pump up to 342 litres/hour and if pumping vertically to 4 metres will pump at 156 litres/hour.
