If I make it the same length as the existing ones, it wont fit. There will be no way to install it w/o removing the roof plankings.
My only idea is to make it shorter and cut the piece that sits on the block
wall, cut the angle 1.5" higher. This will allow me to slide it in further,
then lift up the ridge end and pull it into place. Then place a 2x4 below
the angle cut on the block wall side. Clear?
My jpg shows a drawing of existing rafter with the red line how Im thinking
of cutting the sister. It would be weaker, but this is all that i can think
of. If I do this I will attach it with screws and glue to the block wall top wood and bolt it to the existing rafter two bolts 1' apart at each end.
better ideas?
pics and my drawing: http://s276.photobucket.com/user/paulsmars/library/RAFTER SISTER?sort=3&page=1
please ignore the 1st incorrect jpg drawing. I cant figure out how to delete it. No wonder I stopped using photobucket a long time ago!
better ideas?
