Roof rafters help
12 Aug 2021
Hi
I’m upgrading my roof rafters to accommodate a dormer conversion and I need to install 150x47 c24 timbers with a birdsmouth cut onto the wall plate. A third cut is 49.5 which the timber rafter will be 25mm to tall to the existing roof rafters of 75mm.
how do I loose this height difference so the roof stays the same height??
thanks
So why 150mm timbers? Did you ask a structural engineer to spec 75mm timbers by doubling them up or/and with additional purlins etc..
Probably to accommodate the 100mm between insulation and ventilation.
