I have sprung a leak from the joint between the water supply copper pipe - 15mm - and the plastic screwthread part of the cistern float valve. Tried tightening but to no avail. May have damaged the float valve thread so will be ready to replace that if necessary. The nut on the water pipe looks like it needs replacing too. But what sort of connector do I need for this ? Would one of those 300mm long, flexible tap connectors do the job ?
John
John
