Whilst replacing joists and flooring in our hallway I've discovered that corner of the house has lying water in the underfloor void. This is probably why the flooring has gone and that we suffer from condensation in the winter.
I've started clearing the oversite which is like mud but as I take the level done, water runs from under the stair well which is at the front of the house. The water is clear and not smelly and as we haven't had any significant rain for the last four or five weeks I'm feeling that is must be an underground water course.
Interestingly the lounge void is next to the stairwell void at the front of the house and is dry. This confirms my suspicions that the watercourse runs under the corner of the house.
My thoughts are to dig a hole outside on that corner of the house to see what is going on. If I find running water how can I make a lined sump so that I can divert the water away from the house. I would then fit a sump pump to take the water away. The sump would be fed by a french drain running along the front of the house.
Your thoughts on this would be welcomed as would alternative methods to solve my problem.
Richard
PS: I've checked the mains water supply and we have no leak.
Richard
