I've looked at a few guides, but none seem to cover this. I've put the last stud on each wall adjacent to one another, each one is about stud's depth (3x2, about 65mm) from the corner, then put a couple of blocks of wood in the corner to keep the two walls from moving against each other.
I made it so there is 1200 distance from the outside corner to a stud, so the outside plaster board will be uncut, but that means the inside plasterboard will have to be cut, and the internal corner won't have any taper where the boards meet. (Or was I supposed to add an extra stud to avoid cutting the internal board???).
Anyways, my main question: Is it normal to leave the plasterboard unsupported right at the corner or do I need to add more support for the edge? Also, any idea what kind of bead is best for this? Plastic? Metal? Just tape it?
Hope this makes sense!
cheers,
S.
cheers,
S.
