How to refill a Glowworm swiftflow 75/80?
4 Apr 2008
Merseyside
Anyone know how you do this? I don't have the manual.
Also if anyone has the manual I would greatly appreciate it.
thanks,
should have one of these near boiler
Thanks a lot guys. All done.
Great site by the way and fast responses. will sure to keep this bookmarked!
OK. Just one last thing.
It may now have released too much water. Is pressure ok at 3?
I released enought to fill it to 1.5 and I thought i had closed it properly but it how shows as 3.
The thing is though is that the valve is a screw and it appears that you can turn it as much as you want. Unlike a normal screw which tightens this doesn't. Is this right? Do i need to turn at a certain angle to close the valve?
I think it is closed though as I set it back at the position it alread in but I just want to make sure.
slot should be accross pipe for off, disconnect to make absolutely sure.
drain some water out of rad bleed or a drain point, gauge should read 1bar when system cold
