How to repair this
3 Dec 2009
Yorkshire
Hello
As a result of some new boiler pipes being fitted through the ceiling it caused some of the paint to crack. I have scraped away the loose and flaking paint and now I need to repair it.
What is the best way of doing it? I'm not sure whether to fill it, caulk it, sand it??? Although it does look a bit too wide to caulk.
Your help would be appreciated .
Phil
It looks a little like the old plaster wasn't sealed very well round the edges before it was painted. I'd scrap and sand off any loose old paint then seal with a pva/water mix, and then repaint.
Gobz
A pva/water mix !!??
Would watering down normal emulsion (mist coat) not do the job ?
Surely the pva route would stop the emulsion soaking into the plaster and allow it to peel away again ?
Guys ?
Stoyer
Don't use PVA on a surface that you intend to paint.
Once you have all the loose/flaky paint removed,, flush over the area with a couple of "thin" coats of ready mix joint finish, (much better than caulk). Put one "thin" coat on, say today, let it dry overnight,,, then put another "thin" coat on tomorrow, sand it down when dry, then paint it. Feather it well at the edges where it meets the paint,,, you'll never know it's been patched.
Roughcaster.
Err Ive used pva mix plenty of times to seal plaster with no problems, In fact I've just plastered a 6m x 3m room done this and decorated and guess what, a month later no problems.
Perhaps your mixing the pva a little thick, its no different to watered down emulsion.
Also in this case if the plaster wasn't sealed correctly in the first place splashing watered down emulsion over it could worsen the problem causing more paint to bubble and peel away.
Gobz
I agree with roughcaster, ready mix joint cement, pick it up from any DIY store, i`ve used it to hide a multitude of sins in my house.
