Hello,
My mid position actuator bgmvsp-23 is stuck somewhere between CH and HW as the rads heat up a little when only the HW side is on.
It seems to me that the actuator can be removed WITHOUT doing any plumbing - is that right? It looks like the actuator mechanically turns a valve so presumably I can pull it away from the 3 port valve without fear of any water escaping? It seems to be sort of clipped on with a couple of catches, do I release those and carefully pull it off? (After isolating the power of course).
I followed the advice on this forum and have ordered a replacement Drayton MA1 but need some tips on how to swap them over.
As the valve is stuck between two positions, do I need to move it back to one position before putting the new actuator on and how do I know which way to move it?
Thanks very much in advance
