How to reset garage cable back into groove wheel?
Going to have a crack at this over the weekend. Just to check.
Take tension off the spring via rods/grips
Do I tighten grub screws to stop spring springing back to original postition
Realign cable.
Restension spring and retighten grub screws.
Cheers
Lost me with grub screws??
Just going by a few videos that I watched, securing the spring by tightening grub screws
Sounds to me that your videos are about completely retightening a spring on the shaft by rotating the loosened spring retaining block around the shaft then tightening some grub screws hold it in position, nothing to do with my method but more than one way to skin a cat, good luck
Correct me if i'm (which I probably am). Will the spring just not go back to the original position if there is nothing to lock it?
Probably/possibly/definitely depending on what your plan of action is to remedy your problem. My advised method way back when was basically taking the tension off the wire by clamping onto the drive shaft with something and turning it backwards 1/2 a turn against the force of the spring, adjust the slackened wire in the gloves and then let the tension back off the shaft
Cheers bud, all sorted, took less than a minute to fix.
