how to reset the trip switch on a Hotpoint dwf 30 ?
19 May 2011
Devon
My dishwasher has tripped out and will not start the cycle, although the red lights are on. The bottom was full of water which I have dreaned, I have the left hand panel off and can see the trip mechanism but can't get it to reset. Ant ideas?
There is no trip switch only a poly float in the base if it's full of water drain it out the it should start to fill, is the pump blocked
I have the left hand cover off now and have found that if Imove the red float upwards the machine starts up but still does not take water in. If i pour water in to the bottom it pumps out OK (when I lift the float) so that part of it works.
If it's not taking water in clean the matrix on the side remove all the gunge and then clear out the ribbed tube that goes to the sump.
Thanks for your help rocks1, it looks like an electrical falt, and as its an old machine i have decided its not worth spending money on. cheers anyway.
