How to set maximum water temperature on Vitopend 200??
19 Aug 2009
Hello ,
I'm tryin to set the maximum water temperature on Vitopend 200..... however, i cant seem to get it right :-(
Basically, i want to set the temp. of the boiler in such a way that, water is not heated past this temperature and if the temp. falls below the set value, the boiler should automatically heat water to the set value.
E.g. I would like to set the temp. as 50°C so that water always stays at this temperature. If water temp drops below 50°C the boiler should heat water to 50°C again......
Any help will be much appreciated....
