- Joined
- 15 Jan 2016
- Messages
- 2
- Reaction score
- 0
- Country
Apologies in advance for a probably stupid question, I know absolutely nothing about plumbing!
I have recently had a new washing machine fitted and the hot water pipe no longer needed has been capped off but I think it must have been done wrong and has resulted in a 'dead leg' as now the boiler comes on when any cold tap is turned on. There is also some occasional spluttering from the taps when first turned on.
Is this a problem that I can solve on my own or do I need to get a plumber in? Bearing in mind that the only one I know did this capping off in the first place.
I have read some forum posts and they say to "Run some water fast out of your capped off hot water pipe in case you trapped some air inside." Does this really mean to open the pipe and let it leak out water, then close it back up?
Any advice would be greatly appreciated!
