Recently had 'stacker' type patio doors fitted. Although it has rained many times since then with no problems after first *big* rainstorm last night I find water is coming in underneath them at one end (red arrow in picture).
The doors have been packed up to level them, leaving a gap of maybe 5mm underneath. Should this not have been sealed somehow with spray foam? I don't know what the normal procedure should be. There is a possibility that sitting water on the outside frame (green arrowed) is leaking in somehow but I think this less likely.
Fitter says maybe it was installed too close to the ground (!?!). Its 120mm off the ground level outside and there is no sitting water there anyway (under the deck), so I think this is him trying to shift the blame. Window supplier is going to come and check anyway.
My feeling is that this simply needs to be sealed/filled in underneath where it was packed up when it all dries out. If any pro fitters out there can confirm if this is right, and suggest a suitable product (spray foam, silicon?) if so I would appreciate it. All the best, Nick
