How to stop leaking capped pipes ?
1 Dec 2009
Hi everyone
I was wondering if anyone had any advice.
My problem is i have a 5inlet soil inspection chamber on my patio there are two soil pipes from the house going into the chamber & the one outlet that takes the waste to my biotank(fancy septic tank).
Problem is that the two spare inlets have been capped off but ground water is getting through. Obviously this is bad because the bio tank is only meant to take household waste water not ground water.
Does anybody know what i could use to seal these caps properly. The chamber has been set in the ground and there is no way to remove caps or anything else.
I was thinking of waiting for the weather to dry out and cover the caps with mastic & aqua seal, to stop the water seeping through.
Any help greatly appreciated
Darren.
