- Joined
- 17 Feb 2006
- Messages
- 396
- Reaction score
- 4
- Country
OK, got the towel rail on the wall. I'm about to hang another rad then will drain down to connect up.
Both these are upstairs. Is there an easy way to tell when the system is empty upstairs. I don't want to completely empty it if I don't have to.
It's an Ecotec 837 combi. Presumbly the routine is:
1. Turn off boiler.
2. Connect hose to drain tap and turn on. Go round opening bleed valves upstairs.
3. Do my stuff.
4. Turn boiler back on and open tap on filling loop until pressure correct. Go round and bleed rads one by on. Keep repressurising till done.
I was going to add a bit of x100. but I'm not sure what's in it at the moment. I found an empty bottle for Salamander Corrosion Guard under the floor, but somehow I thought I'd seen and emtpy x100 bottle. Does it matter if I mix? Or shall I wait until all this is over and get somebody else to competely drain and refill (the boiler needs servicing anyway). Will a few weeks without much inhibitor in it do any harm?
Many thanks, Mike
Thanks, Mike
1. Turn off boiler.
3. Do my stuff.
Many thanks, Mike
Thanks, Mike
