How to wire Accenta mini G4 to a Pyronix Belle
6 Jul 2011
Hello, I ask your help for wiring an Accenta Minin G4 to a Pyronix Belle (FP04002C-Batch 4610). Here all connexions avalaible :
Accenta Mini : STROBE +, STROBE -, T (SCB), A (SCB), D (+ BELL), B (- BELL), SET. Note that the accenta mini have by default a strap between T and A.
Pyronix Belle : B- (0 volt), B+ (12 volts), BA (Bell activate triger), STB (Stobe activate trigger), BT (Belle tamper), TF (Temper feed : put to 0 for negative return OR 12 volts positive tamper return if another bell is used).
According to me here how it should goes :
Accenta connexions / Belle connexion :
STROBE + / STB
STROBE - / NOT CONNECTED
T (strap removed) / BT
A (strap removed) / B-
D / B+
B / BA
SET / NOT CONNECTED
I do a strap on Belle between B- and TF. Finally I set Belle's jumper polarity trigger to negative trigger input applied.
I am right ?
Thanks,
Regards,
Pascal.
