how wide does plasterboard wall need to be.for electrics?
9 Apr 2014
Hi, I am attempting my first go at battening to an internal wall to affix plasterboard lining. We are having some rewiring done in this room and a new cooker point moved to where I will complete this plasterboard drylining.
What im stuck with is how wide does the batten need to be in order for the Electrician to fit a cooker point into the plasterboard wall? I have some 22mm thick batten which is fine for the cabling but will the electrical box part of the cooker point fit?
Thanks in advance.
Read more: http://www.diynot.com/forums/plaste...-befor-elecrics.399006/#3075949#ixzz2yTYZeSYU
Cooker backboxes are 47mm depth, so about 12mm will have to be cut out of the wall.
However this is of no relevance at all - it's only one box.
Use 35mm boxes for everything else as already suggested, they can be fixed directly to the existing surface, the 22mm battens + 12.5mm plasterboard are near enough the same depth.
If it's a kitchen, make sure you either run a batten around at the height of the top of the cabinets, to give a fixing for the cabinet wall plates, or web the wall with ply before then plaster-boarding. Never a struggle for a fixing then!
