Evening all. This is my 1st house (built 1934) & I'm just getting started in DIY. I found that the brown silicone sealant around outside of kitchen window has deteriorated & wooden sill beginning to rot in corner by bricks & mortar. After poking around I found the mortar to be crumbling away & has broken up badly in the gap visible below - which goes back several inches, as far as some white insulation stuff. The photo maybe doesn't show how deep it goes due to the angle.
I have started by applying Ronseal wood hardener to the end of the wooden sill after cutting away the small amount of softened damp wood.
My question is how can I repair this? Should I fill the gap up with mortar (any particular product suggestions welcome, as I've never bought mortar or mixed cement eg Sika Mix&Go). I've seen people suggest using 'expanding foam' - is that an option too?
I assume that it would make sense to apply a thin waterproof silicone sealant layer on the outer surface also.
Any help welcome. Cheers.
[/url]
