Not really, just wrote that title to get someone to respond to my post:
My CH system is sucking in air - the symptoms are that when it first comes on at 6am, no probs, but then by about 7 the thermostat cycles and when the pump comes back on there is a lot of bubbling and gurgling in a particular upstairs radiator as air has been sucked in or boiled out of the water and then pumped to that radiator.
The boiler is also kettling somewhat.
It's a Potterton Kingfisher CF on an open vented system with the pump on the return.
Could the kettling be generating air bubbles which are ending up in that rad, or is it most likely to be air being sucked in, and if so, what is the best technique to locate this unauthorised air intake?
