hygena apl 4225 oven
6 Jul 2010
Yorkshire
The main oven door on our hygena oven is quite loose when closed. Looks like the springs need tightenning up or replacing.Any ideas?
Hygena are defunct but its not the springs normally.
The door rollers wear and the teeny slot on the bottom of the door hinges that fit in the door rollers wear,
There are sort of temp repairs that can be done
I use a piece of thin stainless steel or a piece of steel from a can
You make a small shim that will fit over the bottom of the door roller where the door hinge fits on,
Always assuming the roller if your oven has one has not worn away.
