OP, you seem to have said that you have a few rads in series ( one pipe system ) and the circulation is currently by gravity.
If that is the case all you need to do is to add your extra rad in series together with a pump controlled by a room stat and a pipe stat connected in series. With the pump creating the flow you could use your 15 mm tube.
hi doitall so the two pipes from the boiler flow and return i can pipe to them and change the pipe work of the existing rad![]()
Don't talk rubbish Tony, your confusing the OP, at least look at the sketch.![]()
