I HAVE TO BLEED ONE RADIATOR DAILY!!
10 Nov 2007
One of my radiators will not heat up when I put the central heating on. When bled, it works fine but I now have to bleed it every day. Is there something I can do to fix this problem permanently?
Thanks x :confused:
You could fit a mini auto air vent in replace of the bleed valve, but it suggests to me that air is entering or building up in the system due to design/age etc this needs looking at first.
Check there is water in your small tank in the loft. Could be sucking air from there if not.
Put a small jar of water over heating open vent and turn on heating, if it gets sucked into vent then this is where air is entering system.
