Hi StaticPhilly -will you ask the moderator to lay off me. He or she thinks I am a spammer and won't let me explain.whats with all the posts? you already started a pointless one just like this. i mean come on, just change the format of your question, insted of putting links or what ever the problem was just put what, how much and specs without saying were from etc.
Which supplier would quote a per sheet price for corrugations that small to my local shop?try your local small diy shop,
if we get a customer that needs a sheet of what ever material, mdf, plie, aluminium and so on we will get them, if we think it will be a one off we just get the amount the customer wants.
cheers,
Pnil
It is not for a roof or anything big or external! If I was a big construction company, a professional architect or the like I could probably easily get huge volumes of the material from companies who supply for big construction projects.How much do you want? A shed roof, a house, or what?
Corrugated is light and very stiff in one dimension. It means I can bend it as well in the other not-so-stiff direction, to make curved shapes.Why does it have to be corrugated?
Nice idea but the problem is this - I am very particular about the size of corrugations I want - small around 1cm wavelength.Have you tried approaching a local firm that build/clads industrial/commercial buildings?
See if they have some surplus sheets or panel offcuts.
Thrown loads of offcuts of similar stuff away in the past.
There's a company called Architectural Stainless based in Essex. They make heat exchangers that use a folded/fan type arrangement. They might be able to supply you or point you in the right direction. (if mod 6 had seen your post you'd have been ok )
Found this link http://www.architecturalstainless.co.uk/[/QUOTE]
Thanks. I wrote to a good many companies like that but not that company yet so I will write to them and see if they can help.
You mean this?I wonder if Chequerplate would do? You should be able to get it fairly easily.
