HI, new to the forum here, please can anyone help me solve my heating problem:
House - 3 bed semi
Boiler - Ideal Classic 250 FF, approx 14 years old I think (came with the house!)
(Standard vented system with F & E in loft and hot water tank in airing cupboard, boiler on the wall under the stairs.)
7 Rads in total, all new, replaced with all new valves, new 3 way valve and new pump 12 months ago last winter.
Boiler has been kettling and whining this winter, and the rads only lukewarm approx 35 degrees. Also can hear air in system pipes but none in rads.
I've just run DS40 through it for a few days and cleared a load of scale from the expansion tank (and drained and refilled) as I had thought it was the boiler scaled up. The flow seems pretty good round the system with an even temp achievable throughout and no cold or hot spots.
Kettling has improved but still a little bit at times.Boiler is still only heating the rads up to 35 degrees C, and the exit pipe from the boiler only reaches 40% when all the rads are on, but it did reach 60 for a short while yesterday when only one rad is on (boiler thermostat contoller is set to max).
I find that when I try and balance the system I can do the upstairs 4 rads ok and got a temp in the high 50s initially, but once I start switching on the downstairs rads the whole system drops to the mid 30s. I now also get a hissing sound from some rads where they are throttled back.
Can anyone please advise a way forward please?
Thanks, Al.
PS I should add I seem to get a lot of air that is hard to expel after draining - it only has one vent which is on the HW intake - should I fit one to the heating flow too? Or should it be adequate that it vents to the F & E tank? - just worried there's a lot of air bubbles stuck in it.
House - 3 bed semi
Thanks, Al.
