Ideal Classic RS 250 Not Working
if it has a perm pilot (not electronic ignition) it could be over heat stat tripped (think its on rh side but need to remove bottom panel to get to it red button)
No red button that I can see
have you pulled the bottom case off? if so on the right hand side under the boiler you will see a red/orange button push it. if it doesnt move and you hear no click move on call a gas safe man, does the fan run
no fan, its a balanced flu
Has the electric supply been checked for mains power getting to the boiler?
Them boards are quite easy to work on with the way voltages go to diff components
have you got a frost stat fitted? one shut the boiler off before when it died
Yes, can this be reset or bypassed to see if it is that??
Disconnected the frost stat and tried it again, still no gas and cant find any reset buttons or switches. I have power into the gas valve and pilot light is on, is it safe to assume its a dodgy gas valve?.......
