- Joined
- 24 May 2023
- Messages
- 5
- Reaction score
- 0
- Country
Hi, everyone
I'm struggling to find the answer to the problem I'm having, The boilers CH works absolutely fine. The issue I have is the boiler will not produce hot water on demand.
When a hot tap is turned on the boiler does not do anything, my understanding is that the boiler is supposed to fire up when a hot tap is open. I have noticed that the preheat isn't working either the boiler is just sitting on Display 0.
No error codes are showing up.
Heres what i have tried so far;
I have replaced the diverter valve head, and PCB. No change.
I have removed the diverter valve and tested that the valve is moving in and out without getting stuck.
I have removed the heat exchange and flushed it out, to make sure there are no blockages.
I have tested the ohms on the thermistors, the central thermistor is reading 9.5 ohms
The return flow thermistor is reading 9.5ohms
The DHW thermistor is reading 12.4 ohms.
I'm not sure what else to test/ try now
Does anyone have any ideas as to what's going on?
