So been trying to sort this for a while , 1st started leaking few weeks ago from dhw outlet on heat exchanger plate, so bought the hydrobloc seal kit and replaced them... Leak then seemed to be slightly worse and spraying a bit instead of just dripping...so thought it was a pin hole in plate itself just round back out of sight so got another plate and new seals again... refitted and exact same leak...replaced the 15mm O-RING on the dhw outlet stub on the manifold just in case that's where it was spraying from ,but no same leak... finally got a tiny mirror on a stick in right position to see and can see it seeping out of the dhw outlet join on the manifold/plate seal. How would this be ,I've changed all seals twice!! Some of the seals did look slightly wedge shaped but they're fine in the other 3 I've replaced. I've ordered some ideal branded ones to try but anyone came across this issue when replacing the o-rings on heat exchange plate??
