Boiler and CH installed 5 years ago, nothing but trouble.
Have contract with installer but engineer never here more than 10 min for "service" and only removes front panel.
Only had luke warm water for a year until I diagnosed and insisted the heat exchanger was replaced after seemingly random guesses and replacement parts.
Now we lose pressure, seems to happen when CH switched on, ok if hot water run and as long as CH not turned off and on again holds the pressure after initial loss.
The engineer has not looked at the boiler although I identified two points of moisture from pipes/ casing - he dissmissed this. Leak seal has been injected for second time and pressure was 2.5 bar now 1.5 bar after 24 hours. How long until leak seal works if it is going to please?
Also now sounds like air/ debris in pipes/ boiler when it starts up.
Any suggestions welcome please I have a year on my contract and want this fixed properly.
