Ideal isar he30
30 Nov 2008
Manchester
Hi Peeps
Need some advice i have the above boiler and it has suddenly decided to stop working,Looked at the manual no fault code is showing.
It attempts to fire fire up then stops and so on and then the circuit board starts clicking again and again and just keeps doing that till you turn it off, The display only shows a minus sign and a little dot on the right handside? (-.) and hasn't changed since it started playing up.
Please help guys.
Pcb but also check your earth. Faulty earth can give a clicking from board. Dot dash in display though is usually main pcb.
I suggest chuck the boiler.
Ideal boilers are awfully unreliable, look at £200 for a pcb every few years.
Idea admit they have had problems with the pcbs and the manufacture
of them. So why they haven't made them much cheaper knowing there
is a problem with them is very bad for their poor customers
who have to put up with the boilers.
Hi Guys
Thanks for the replys, so i need a PCB board you think?, it does go through its strarting cycle but then the board starts clicking.
any other thoughts from anyone?
would check purple wire first if it was me,connected to pcb and user control
