Hi again guys. When refilling the CH system having added inhibitor, I 'inadvertantly' allowed the system to overpressure, and the gauge went to full scale. Instead of the PRV opening, water leaked from somewhere at the back of the boiler cascading down the wall. The PRV discharge pipe is connected correctly, this happened late last night at an empty property, and I will check the PRV manually tomorrow.
I have come across these stuck slightly open before, but not heard of them sticking closed. More importantly, where would the leak have been most likely from? Once the the pressure was reduced the boiler ran OK with no leaks, I then shut it down.
