Ideal Isar strange pressure behaviour
  • Thread starter Thread starter mystifiedboilerowner
  • Start date Start date
M
Hi everyone,
I have a HomeServe contract so am covered for engineers looking at my boiler and central heating, but I suspect the issue I'm having is going to be tricky to diagnose, so I thought I'd just ask here in case anyone's answer might be able to point me and the engineers in the right direction.
I have a twelve-year-old Ideal Isar HE24 (yes, I know what you're all thinking, but I am at least covered every time it breaks down).
The issue I am having just now is that the system will sometimes suddenly lose a little of its pressure, but then carry on as normal without any further pressure loss.
To be clear, this is not the steady, gradual drop in pressure that I assume (please correct me if I'm wrong) most people would see with a typical leak. When completely cold, my boiler is usually topped up to around 1 bar or a little more, but on two occasions recently, over a period of a few hours, the pressure when cold quickly dropped to 0.75 bar and then just stayed there with no further drop of pressure occurring.
For example, immediately after one such drop, I topped up the system to about 1.1 bar on 7th August, continued to use it as normal for heating and hot water, and found the 1.1 at cold was maintained solidly until 17th August when there was a sudden drop of the pressure when cold to 0.75 bar. It is now 21st August and there has been no further drop of pressure, which remains at 0.75 bar when cold - I am keeping it there for now rather than topping up further in case I can see any further drops in pressure over the coming days.
I have found no connection between heating being on or off and these pressure drops, nor to hot water use and pressure dropping (not that there would be any). The only thing that seemed to happen on two occasions recently when I suddenly lost a little pressure was that there was a spell of cold weather. I did not use the heating any more than usual on either occasion as a result of the cold snap, so I think this is likely just a coincidence, particularly as I have been running the heating and the boiler has pretty much got to full temperature every morning since the last drop on Friday, with no further loss of pressure resulting from this use of the heating every morning. The drops in pressure do seem to present as single, isolated events, and between the occurrence of these pressure drops, everything seems to be working normally.
I have had both the expansion vessel and the PRV replaced recently as the pressure was climbing to 3 bar when the heating was on and water was coming out of the relief valve. This issue is now solved and the pressure when hot is within normal range (about 1.75 bar) - but I still get these intermittent sudden decreases in pressure. I can't see any evidence of a leak around radiator valves, but something like this probably wouldn't be visible. If there's a leak under the floorboards, accessing pipework shouldn't be too difficult - crawlspace under ground floor and upstairs floorboards should come up without too much difficulty - but I'm keen not to do this if the results are going to be inconclusive, which is likely given the intermittent nature of this issue.
Any thoughts would be very much appreciated.
Thanks nwgs. I'll look into that. I mentioned leak sealer a few years ago to the engineer servicing the boiler - that was at a stage when this wasn't happening so often or so noticeably - probably less than once a month - and he said at that stage there was a risk of blocking the heat exchanger. Maybe could do with revisiting the idea.
The gauge is a bit all over the place but was down to 0.6bar when I came in tonight, so have now topped up to 1.1 and might give Homeserve a call tomorrow. The last time I mentioned it, the engineer seemed pessimistic about the possibility of being able to find anything as small as this, and the advice at that stage was to wait for the problem to get worse if it was going to, and show itself then.
do not use leak sealer it will cause more problems than you already have
Thanks all. I've held off on calling anyone for now. The pressure needle has not moved one iota from top-up last night. Have disconnected filling loop in case this improves anything (highly unlikely) and tied tissue paper around radiator pipes to see if anything shows up (again highly unlikely in my case). Might give engineers a go again at next noticeable pressure drop but I suspect they are likely to say exactly the same thing as before so we shall see. This is probably just going to be a long waiting game to see what (if anything) fails first, but it may all come out in the wash when the boiler needs replacing (which probably won't be too long from now) and system needs cleaning out and checking over then - could always go for a few new rads and/or pipework as well as the boiler if it looks too bad. In the meantime it's good to have heating that still pretty much works the way it's supposed to.
By the way, is it normal for pressure to climb from 0.75bar to 1bar when I run hot water or the DHW preheat kicks in? It was doing this yesterday. Now that I've topped it up to 1.1bar, the pressure does not climb AT ALL when I run hot water or the preheat runs - no movement of the needle whatsoever. I'm guessing this is irrelevant to any of this?
Ct1 leak sealer is decent. Put it in the flow side and it will do its job before it makes it back to the boiler.
Each to their own.
Still monitoring for now, just in case there's anything at all I can eventually report to engineers that may be of even of some remote kind of use. Pressure has still not moved one jot since top-up two days ago and I'm making full use of CH and hot water. If it follows the usual pattern, there will be a sudden decrease to something like 0.8bar at some point next week.
